double image on C6501
  • punchi.com
    • Aug 2025
    Please help, i am having an issue on a C6501 with regards to a double image on half of the page, the PM's have been done recently including the transfer roller and belt and fuser belt, when i do half tones the double image only shows on the yellow and magenta units, what can i try, really urgent!!
  • Gaffers01
    • May 2011
    • 335
    Re: double image on C6501
    Can you put a sample up so we can can have a look?
    • punchi.com
      S12100712081.pdf
      • Gaffers01
        • May 2011
        • 335
        Is that the first print out or second?
        If its the second the belt is NOT cleaning properly.
        can I just ask that when parts were replaced that you ran all set-up procedures, as i have seen some odd issues before if they haven't been done to the letter?
        • Albonline
          • Sep 2008
          • 1153
          cleaning blade lock screws in the drums?
          • punchi.com
            the cleaning blade screws have been taken out, i have replaced the cleaning unit on the transfer belt,
            all setup procedures have been done accordingly. double image is on the first print out , what can i try?
            • Albonline
              • Sep 2008
              • 1153
              if the repeat is on trail side of copy then you might have a tempurature issue in the fixing unit. output in each color and see if only one color is doing this. what size and orentation is the image you put up?
              • punchi.com
                out put on each unit - half tones at 200 saturation, magenta and yellow show double image on the trail end, it was A3 Landscape,
                how do i check the temp issue on the fixing unit if this is the case?
                • 907tec
                  • 434
                  Am I the only one who still does stop-tests? Just crash the machine mid-cycle and find out which section is causing the defect. At the very least it will help you focus on a smaller area of the machine.
                  • Albonline
                    • Sep 2008
                    • 1153
                    If it was fuser all 4 colors would be doing it. I strongly suspect the drum cleaners in the two colors that are double imaging. trade the drums around and see if problem moves with them.
                    • Synaux
                      • Mar 2012
                      • 1224
                      You might want to check I/O connectors. If you have a loose ribbon/connector weird things can happen...
