Permanent error c 2152 on Bizhub c 203
  • ogaliandy
    • Apr 2012
    • 14
    has any one experienced C 2152 which is permanent, i changed the Transfer Belt, the Fuser Drive Unit and even the Transfer belt sensor inside the machine, it goes away then after several copies to comes back permanent, has
  • Shadow
    PHD in Sh!t Disturbing
    • Sep 2011
    • 455
    Re: Permanent error c 2152 on Bizhub c 203
    remove the transfer belt and retract the pressure roller by hand, turn the gear.
    check to see that the pressure roller has not popped out of place.
    reinstall the belt and power the machine off.
    re-power the machine and see if the error code returns.
    don't forget to clear the jam and error counters and check the history of the errors.
    baring this I would be inclined to check the drive gear for the transfer unit pressure roller on the main frame.
    my educated guess would be that the roller has popped out of place.
    $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • kingarthur
        • 1369
        got a feeling there was a firmware update to do as well...wouldn't do any harm to install the latest anyway
        • ogaliandy
          • Apr 2012
          • 14
          Originally posted by Shadow
          remove the transfer belt and retract the pressure roller by hand, turn the gear. check to see that the pressure roller has not popped out of place. reinstall the belt and power the machine off. re-power the machine and see if the error code returns. don't forget to clear the jam and error counters and check the history of the errors. baring this I would be inclined to check the drive gear for the transfer unit pressure roller on the main frame. my educated guess would be that the roller has popped out of place.
          Thanks for the info i will try that
          • ogaliandy
            • Apr 2012
            • 14
            do you have the firmware it would hurt to install it as well
            • kingarthur
              • 1369
              Sorry cant help you there, you have to get it from Konica Minolta
