BH600 Second Side background
  • JR2ALTA
    • Feb 2010
    • 2033
    Both sides clean on a simplex print.
    Duplex prints have background on second side only.
    Tried transfer unit.
    I will try HV board next.
    Voltage should adjust for the second side, so I am guessing there is something whacky going on.
    Has 1.5 million on it.
    Thanks in advance!
  • kon
    • 55
    Re: BH600 Second Side background
    Thanks in advance!
    Seen this happen when way over pm cycle. Also when adjustments are off most often Ld1 Ld2. This use to happen on the old 7255 all the time from a bad drum ground.
    • JR2ALTA
      • Feb 2010
      • 2033
      What did you do for the bad drum ground?
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • JR2ALTA
          • Feb 2010
          • 2033
          Ld1 and ld2 thanks!
