konica minolta 250 cl3 replacement
  • DOE
    • Mar 2010
    • 258
    can anyone tell me how to get to the first drawer feed clutch. i have not worked on the 250 much so i am not real familiar. i took out the first feed unit and can see it back there but have not been able to get to it from any direction. i am probably overlooking the easy way. paper will not feed from first drawer. thank you for any ideas.
  • kingarthur
    • 1356
    Re: konica minolta 250 cl3 replacement
    you need to remove the bypass completely, then the 2nd tray feed unit, then you can remove the feed unit, you'll need to remove the back cover when you reassemble it, to reconnect the connector
    • Hansoon
      • Sep 2007
      • 3385
      Why are you guys replacing those clutches so often? We just blow them out with compressed air and than soak them with brake cleaner. Blow the liquid out again after a minute that's it.
      With hard to reach clutches we even try to do this in the machine sometimes.
      Hans
      • JR2ALTA
        • Feb 2010
        • 2033
        I'd rather replace the clutch than "soak it in brake fluid"
        No creativity points.
        It's possible to plug in without taking off back cover. The whole thing is a pain
        • Hansoon
          • Sep 2007
          • 3385
          Works well, believe me. Doing this since the EP-5400 / 4050 / 5000 / Di-550 years without problems.
          As long as they are not sticky from residual magnetism it works and even in that case they can be demagnetized with an AC coil.
          We are Indys not a big company and have to cut costs by any means. Those clutches are not the cheapest.
          Hans
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            those clutches are under $10, they go straight in the bin with the slightest doubt with me.
            Also, i have replaced the tray 1 feed clutch in situe with minimal disassembly, but it requires advanced contortionist skills. (like most things designed by the japs)
            • Darren King
              copiertech
              • 652
              Hans
              It is way cheaper to replace it the first time than to have to drive back three days later and take it all apart again.
              Darren
              • JustManuals
                • Jan 2006
                • 9838
                Paul@justmanuals.com
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  This PITA clutch reminds me of a helpful hint!
                  When a e-clip is at risk of falling put a dab of grease on it. it will stick in place letting you clamp it down with one hand.
                  • Hansoon
                    • Sep 2007
                    • 3385
                    Are we talking about the same clutches.......??
                    Konica Minolta 9322-1000-81 for less, with Free Shipping on orders over $199.00!
                    Hans
                    • JR2ALTA
                      • Feb 2010
                      • 2033
                      Nope.
                      Results for 9322 1500 12
                      Should be cheaper OEM
                      • Hansoon
                        • Sep 2007
                        • 3385
                        Yes, but not under 10 US$.......
                        Hans
                        • johskar
                          Solutions Engineer
                          • Mar 2011
                          • 22
                          over here those would cost a customer $19.5 +vat so they can't be that expensive... looks to me like someone is making alot of money on them...
                          The wonderful thing about standards is that there are so many of them to choose from.
                          Yes, I got ADHD, my posting can be quite chaotic at times!
                          • EarthKmTech
                            Step aside, noob
                            • May 2009
                            • 2139
                            i work for the manufacturer - our parts prices are lower than EVERYONE elses
                            and yes, they are under $10 for us.
                            • DOE
                              • Mar 2010
                              • 258
                              thanks everyone. the brake fluid did work. apreciate the help
