C35 fax forward to email only partial page
  • wseyller
    • Sep 2012
    • 1129
    Bizhub C35 is setup to forward faxes to an email. The faxes come in a tif file. Issue happens from different senders. The image in the email is only a third of the entire page. The rest is cutoff. Sometimes they get the full page. Sometimes it is about 1/2 a page. Approx 1/3 is usual.
  • TheOwl
    • Nov 2008
    • 1732
    Re: C35 fax forward to email only partial page
    Is the same thing happening if you just get the faxes to print out instead of forwarding them?
    If the same thing does happen then, I would be looking at the line and firmware.
    • wseyller
      • Sep 2012
      • 1129
      After leaving the call I just though about the idea of doing that. What I ended up doing is I updated to the latest base firmware which included a new fax firmware which had a ton of fixes related to faxing. Not sure if any where related to my issue. Also I noticed a special firmware that added the option receiving faxes in PDF format. Customer preferred PDF anyway. Tested about a dozen faxes that came in as PDF and all were perfect. So if anything maybe i at least worked around the issue altogether.
      Sent from my XT875 using Tapatalk 2
        • 23009
        Most likely this 1/3 page is exactly what would have been printed because of a bad phone line. Fix the phone line and your problem is solved. =^..^=
        • wseyller
          • Sep 2012
          • 1129
          After two days of usage they don't have the issue any longer. So it seems what I did worked because before it happened about 90% of the time.
