Konica 7228 F26-3 0003 L Detect Code
  • yormets
    • May 2009
    • 336
    I know this is T/D related. This machine was running copies when this code occurred. Usually I can replenish toner on these models and redo L Detect and you're off. Not this time. No matter what I tried, the code remained. So I went back to the shop, got a working unit out of another machine. Ran L Detect.....F26-3 again. I physically added toner to this TD unit, same result F26-3. Other than getting new developer (which is pricey) and trying again, what else could it be? Why would it die in the middle of a copy run. I am running OEM toner in my shop machine. The second TD unit. I believe the original unit is running a generic. But that wouldn't explain why the second unit has the same error as the first. Any idea's?
    Roy
  • JustManuals
    • Jan 2006
    • 9838
    Re: Konica 7228 F26-3 0003 L Detect Code
    Paul@justmanuals.com
    • kingarthur
      • 1366
      Are you sure the dev unit is turning, take the unit out & wipe the dev off of the mag roller, then put it back in the m/c and switch it on, if the mag roller isn't covered in dev when you take it back out, then it's either the dev motor or the PRCB
      • yormets
        • May 2009
        • 336
        Originally posted by manuals4you
        This Parts & Service Manual can now be purchased for $12.77 and downloaded immediately after payment from Just Manuals, The Internet's largest selection of manuals ~ Instant Downloads Paul@justmanuals.com
        Thanks for nothing.
        • SmellsHot
          Head Tech
          • 512
          OR enter 47mode. input 50 and hit start...do you hear motor turning?
          Everyone has the right to be stupid. Some people just abuse this privelage more than others
          • yormets
            • May 2009
            • 336
            Thanks for the information. The developer is not turning. I have a parts machine. Is it difficult to replace? I'm going to attempt it in the office. I guess I'll look at my parts machine first. Any tips would be appreciated.
            • TEKK09
              • 142
              I have a 7222 that has the same problem...the mag roller isn't being turned.(see http://www.copytechnet.com/forums/ko...26-3-code.html) But also, the drum does not rotate, but I'm not sure it should as it goes into code within a couple seconds of saying, 'warming up'. Let me know what you find. I'm not lucky enough to have a machine to rob from.
              • kingarthur
                • 1366
                if i remember correctly, you have 2 paper feed motors & one that drives the dev, swap the dev motor over with one of the paper feed motors, the m/c should work, but you'll paper misfeeds
                • TEKK09
                  • 142
                  Wow! Good idea. Just what I was looking for. I'll try it in the morning.
                  • TEKK09
                    • 142
                    I'm trying to confirm that the developer motor and the paper-feed motors are the same, but can't find the part numbers in the service manual. I guess there is a separate manual for the parts, but I haven't been able to locate one online.
                    • kingarthur
                      • 1366
                      as far as i can remember the only difference is the RPM & the rating, but you shouldn't do any harm swapping them over,
                      the part numbers, as far as i can see are 27LA 8001 00 & 27LA 8003 00, items 11 & 38 on page 7 of the parts manual, as far as i can remember those are the 2 to swap around
