Bizhub c300 df-608
  • alfpanasonic
    • Jan 2007
    • 73
    Bizhub c300 df-608
    Error code c8103?
    Any help?
  • mikeena
    Branch Technical Manager
    • Mar 2007
    • 220
    Solution ID
    TAUS0703078EN* Solution Usage 1
    Description
    DF-608, C8103 (C-8103).
    Solution
    CAUSE: Binding or failed lift motor (M7).
    SOLUTION: Check for binding in the lift motor assembly (p/n 9J07R70700) andreplace it if necessary.
    SPECIAL NOTE : Solution contribution by Malcolm Hibbert, Workgroup/SSD
    • CMB
      KonicaMinolta Tech.
      • Mar 2005
      • 457
      yep. we've had several of these lately.
      • Profibastler
        • Nov 2014
        • 102
        Re: Bizhub c300 df-608
        Hello folks,
        can anybody please tell me, where this model was installed in which copier models?
        Where to find datasheets of all DF ADF ?
        Thanks a lot
        • tsbservice
          Field tech
          • 8011
          Originally posted by Profibastler
          Hello folks,
          Thanks a lot
          This is so old thread those models are so outdated or even dead
          If you are really interested why not start a new thread?
          • KMFLT3CH
            • May 2017
            • 235
            Hello folks,
            Thanks a lot
            Only on the (very old) C300 and C352, as listed in the 2014 cross reference pdf.
