Konica Minolta Bizhub C220
  • PEPELEMU
    Tech
    • Oct 2008
    • 38
    I am buying a Konica bizhub c220 from my used copier distributor and the machine has an error, no animation guide data available. I need to get the movie.exe file. I am not a konica dealer. I am a independent service company in NH. Is there any way to get the file if you are not a konica dealer?
    Thank you
    John
  • jotunn
    • 618
    Re: Konica Minolta Bizhub C220
    You've got PM.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • jarobb
        • Apr 2011
        • 6
        google: A0ED0Y0-A000-G00-01_2nd_Movie.exe
        or link: Source
        85,8MB
        • Darren King
          copiertech
          • 652
          If you can't find it the machine will work fine without it.
          • ni311
            • May 2008
            • 658
            It will display a message about it, this is all. It depends on the client, some will ignore it, other will believe the machine is broken and you have to fix it...
            Konica Minolta Error Codes - Explanations and Solutions
            • jarobb
              • Apr 2011
              • 6
              • Darren King
                copiertech
                • 652
                You don't use the service USB port. You use the port next to the control panel.
                Darren
                  • 23009
                  About the only thing I can add to this discussion is the "why?". The HDD was formatted to remove any remnants of the activity log or recent documents. The movie data was just a casualty of the re-formatting. =^..^=
                  • jonbonse
                    • Jun 2009
                    • 737
                    Thank you
                    John
                    Hi, I have bought a second hand machine with the same problem, do you have the 'movie.exe'?
                    • Ciomu
                      Senior
                      • Aug 2015
                      • 4
                      Check your pm.
                      Have fun.
                      • Ciomu
                        Senior
                        • Aug 2015
                        • 4
                        check youre pm
