Konica Minolta Bizhub 421
  • bebe.radescu
    • Jul 2012
    • 54
    I have a bizhub 421 wich for no reason from time to time tells me to turn off the machine and turn it back on so i can use it. And it's worrying me because it started to do it very often, 4 or 5 times a day. Any ideas?
    Thank you!
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: Konica Minolta Bizhub 421
    it may require a firmware update if this is happening because of print jobs.
    are there any malfunction codes associated with this warning ?
    • bebe.radescu
      • Jul 2012
      • 54
      No, there is no malfunction code, the machine just says that i must turn it off and on in order to use it.
      • mrwho
        Major Asshole!
        • 4299
        The only reason I can think of for the machine to, under normal operation, ask for a power cycle is when the network parameters change. Maybe someone's messing with the network settings?
        A firmware update is always a good idea when we don't know what's causing it. At least it takes that out of the equation.
        Mascan42
        Ibid
        • emujo
          • Jun 2009
          • 3009
          Screw firmware, see a shrink....the MFP is talking to you...when it tells you to kill the co worker in the next cubicle, I hope it's not me!!! EMujo
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
              • 23010
              There is an error code, you're just missing it. One letter and four numbers, like C-1183.
              I can understand why you missed it the first time. You didn't know what to look for. But no excuses now. What's the error code?
              • Setright
                FSS / SPM
                • Nov 2008
                • 247
                I would concur, it must be telling you something else besides just power cycling it.
                Is it suggesting that it will disable a cassette?
                • douglasdouglasv
                  • Dec 2012
                  • 20
                  The hard drive is starting to fail. Back up, format. If the problem persists replace the HDD.
