Does anyone know how to restore the upper fuser roller
  • Maindron1
    • Mar 2011
    • 38
    Hi,
    I have several upper fuser rollers with just a few lines which tends to leave a mark on the copies, before I throw them away, I would like to know if there is any way (Known methods) I can restore them if they are not too damaged.
    Thank you.
  • Mick01
    • Nov 2012
    • 362
    Re: Does anyone know how to restore the upper fuser roller
    What Model are you referring to?????
    • Maindron1
      • Mar 2011
      • 38
      It is Konica 7155.
      • Mick01
        • Nov 2012
        • 362
        The answer then is no. They are a Teflon Coated roller. Apart from getting the entire roller resurfaced which will probably be more expensive than a new one.
        • Maindron1
          • Mar 2011
          • 38
          Thank you.
          To the garbage they go!
          • knightfall
            • Jul 2006
            • 633
            in the days of analog copiers I used plumbers teflon tape on rollers to get it going until I came back with the roller but never waited for how long it would last, you could give that a try.
            Get your facts first, and then you can distort them as much as you please.
            • Mick01
              • Nov 2012
              • 362
              They are aluminium so i would recycle and get a few bucks for them.
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                Perhaps they need to start coating aluminium fusing rollers with "Flavorstone" non stick coating. Since they crap on endlessly about how awesome it is compared to teflon.
                Lets put it to the real test inside a fusing unit.
                • SmellsHot
                  Head Tech
                  • 512
                  I heard someone had success using that flex-seal crap, you know the commercial where they install a screen door in the bottom of a fishing boat and spray the screen door with it. I was surprised when I heard it worked......I haven't had the opportunity to try it yet, but I'll let ya know...
                  Everyone has the right to be stupid. Some people just abuse this privelage more than others
                    • 23009
                    Nail polish should work. Maybe whiteout.
                    OK. Seriously, you've got to be kidding. I have seen a mystery substance used. Painted on like nail polish ... and it didn't work worth a shit. =^..^=
