363 wont take firmware
  • kon
    • 55
    replaced mfp pwb and new board wont take mfp firmware. the scanner, printer, fax and adf will load with
    no issues. it doesnt even see the mfp files. tried different firmware versions but same thing. the old pwb will load firmware fine but has other things wrong. need this new board to work.
    • 23007
    Re: 363 wont take firmware
    You may need it to work, but don't expect it to cooperate. Order another PWB. =^..^=
    • Downunder
      • Aug 2007
      • 174
      Have you tried using a different stick say 1gig
      • pepper38_cnd
        Field Service Manager
        • Aug 2005
        • 1075
        Any time I have seen firmware issues where it wouldn't load or even be detected it was usually a problem with the file on the jump drive or the drive itself. You may also want to review bulletin# 8082 to see if any of that may apply to your situation.
        Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
        Now into Ip TV KODI Boxes
        • kon
          • 55
          thanks for the reply anyway the drive and files work on the old pwb and all other recent machines
          its only the mfp file that doesnt show up and load only on this board.
          • Darren King
            copiertech
            • 652
            Did you transfer everything from the old board to the new board?
            • pepper38_cnd
              • Aug 2005
              • 1075
              Hey Daren, I did not think of that does this machine have the small e-eprom? Good point.
              • kon
                • 55
                yep everything was moved. I put a used pwb in to fix the problem and it even took the mfp firmware no problem. its just got to be a bad pwb.
                • Mr Spock
                  Vulcan Inventor of Death
                  • Aug 2006
                  • 2064
                  There were a couple of models that had 2 or 3 different cpu on the pwb. You had to use the correct firmware for the cpu or it will not take. I do not recall which models they were.
