I Want to buy Firmware & ISWTrns to use for Konica C6500
  • truongson
    • May 2011
    • 67
    Hi all,
    I want to buy Latest Konica C6500 Firmware & ISWTrns to install my machines. Thanks
  • JSC
    Gimp
    • Dec 2006
    • 618
    Re: I Want to buy Firmware & ISWTrns to use for Konica C6500
    Originally posted by truongson
    Hi all,
    Paul will get back to you as soon as he has finished sleeping......
    The gene pool could use a little chlorine.
    • truongson
      • May 2011
      • 67
      Thank you, and if send a PM please send to : truongson@gmail.com.
      • JustManuals
        • Jan 2006
        • 9838
        Hi all,
        I have it, EMAIL me at Paul@justmanuals.com
        • truongson
          • May 2011
          • 67
          I have just sent a email to Paul@justmanuals.com . Please check it. Thanks
          • JustManuals
            • Jan 2006
            • 9838
            I got the email just today. I asked him if he sent it from Mars. Sheesh! 2 weeks for an email to arrive?
            • rbachlani
              • Mar 2013
              • 6
              Need ISWTrns for writing bizhub 950 firmware my email id is raheel.bachlani@gmail.com. Can you please help me paul asap
              Regards,
              RB
                • 23009
                Alas, you are a couple years too late. Paul passed ... it must be two years ago. =^..^=
                • rbachlani
                  • Mar 2013
                  • 6
                  ok as per blackcat suggested. Here is what I have done till now:
                  1) I have two bizhub 950. Bought it from a dealer here. One is working fine but the other one freezes whenever i give a job from laptop or recall a data from the saved storage. Or save a file in hdd.
                  2) I pulled out hdd1 and changed it with the other machine and the machine was working fine without any hanging problem. This was just to be sure that the fault was from hdd1 (which is now confirmed).
                  3) I changed hdd1 with hdd2 and which is in the controller so that i can format the drive because there is no option to format hdd1 directly.
                  4) Then I got D002.
                  5) After that I had some sata hard drives from my computer which i tried to again format first by putting it in the controller and formatted it.
                  6) After putting them all again one by one at hdd1 place. I am still getting D002.
                  Any suggestions what should i do
                  Regards,
                  RB
                  • cxtqd
                    • Jan 2011
                    • 46
                    I want to buy Konica C6500 Firmware & ISWTrns to install. Pls quote and payment method, Thanks
                    Email: printkid2011@yahoo.com
