banding C6500
  • csse03
    [CQ] banding C6500
    Has anyone seen this? shows up randomly and in any color.
  • eifling
    • Apr 2011
    • 43
    Re: banding C6500
    This has happened to me a few times. It's totally random like every 50-100 sheets. Someone told me it was charger related but the times its happened was usually followed by developer housing failure. I would like to know the cause also.
    • Mick01
      • Nov 2012
      • 362
      Re: banding C6500
      Hi,
      I have seen this issue when the drum is worn out. charge shorts to the drum. Where is it at with it's PM schedule? I would perform a PM. Replace Drums, Devs, charge units at a minimum.
      hope this helps
      • Mick01
        • Nov 2012
        • 362
        Re: banding C6500
        Hi,
        i have conferred with some of my colleagues and the consensus is drum.
        • MAD0RAM
          • Oct 2012
          • 81
          Re: banding C6500
          I have seen this issue also but drums were within 50% random colors and random times with no reason.
          This also clears as soon as it starts with a run of 50-60k may get 3 or 4 sections with one to two pages of this.
          • methogod
            • Dec 2008
            • 921
            Re: banding C6500
            Used to get this with the older DU-102C's after playing clean drums over and over, we just started using DU-104s. Banding does happen when grounding seems to fail.
            How wore out are the drums/dv/corona's??
            Whats the PM at?
