C6500 Color problems - how to tell if color reg unit is problem?
  • dagoof
    Still learning...
    • 220
    I've had a color issue with a c6500 for quite a while now - it's calibrated using an ES-1000 but the colors are too dark, generally only get close by running the driver at 85%, but even then mid blues can be navy, oranges slipping closer to red and too much warmth in the greys - all in all, too much magenta I think.
    It's running older f/w, but reluctant to update in case it causes other issues. A previous post had suggested that replacing the whole color reg unit might solve it but I'm wondering if there's a way to diagnose if this is the problem or not?
  • methogod
    • Dec 2008
    • 921
    Re: C6500 Color problems - how to tell if color reg unit is problem?
    I would update firmware at least till 60...
    FW fixing alot of calibration issues.
    how old is developer and drums?
    when your running until failure, like we do we find sometimes developer will just give up. may be time to change it out.
    Before replacing color registration board, which is not cheap, I would pull it out and clean it well. Its only one connector in the back - hard to get to, but it can get dirty. Also would verifiy shutters are opening and closing properly, check in I/O mode.
    If you want to get the older color reg. unit cheap there is one on Ebay right now.
    its a little older, but good for testing, i would try to get it for under $75 bucks.
    • Mick01
      • Nov 2012
      • 362
      I would perform the following in this order:
      Remove and thoroughly clean the Colour Registration ass'ly
      Printer Gamma Sensor Adjustment for the screen that is being used (on good quality bond paper like mondi 100)
      Printer Gamma Offsett Adjustment for the screen being used (on good quality paper like mondi 100). Ensure that the this is correctly adjusted.
      Run Auto Gamma adjustment.
      Calibrate the RIP (ensure you are calibrating to the correct screen, stock you are using i.e coated/uncoated). After scanning the page check the Actual vs target curves to see if you are acheiving (or close to) the targets for each colour.
      hope this helps.
      • JustManuals
        • Jan 2006
        • 9838
        I would call a qualified tech in as it's clear you are not among them.
        • Mick01
          • Nov 2012
          • 362
          Thats a bit Harsh!
          • methogod
            • Dec 2008
            • 921
            its the first thing i have ever seen posted except for trying to sell manuals.
            (but the reg unit is fragile and you can make it worse, if you don't know how to pull it out).
            • Mick01
              • Nov 2012
              • 362
              I agree the unit is fragile and easily damaged.
              • Chameleon
                • Nov 2011
                • 200
                Here is how I diagnose all the C6500's I work on.
                Print test page 51 for all 4 colors. If I'm on a C500 I use test page 1 with a gradation setting of 90 for all colors.
                Page 51 should start with white and gradually go to solid color. If there is any light or dark streaks consistent in all 4 colors it is in your transfer unit, or possibly fuser. If there are light or dark streaks in a single color, swap charge units or drums to further isolate. I usually move the worst drum or charge to yellow since yellow hides most defects.
                The halftone test patterns (1, 51) are the easiest way to diagnose color issues with any color machine. If the test page 1 is solid color (255) it will hide most defects, so use test page 1 set around 70-90. The lighter the halftone is the more prominent the defect will become. The only time I run test page 1 at 255 is with all 4 set to 255. This should look brownish black. Then I run a test page 1 with all 4 colors set to 90. If the 4 colors are not even density this will show which color needs adjusted. If one color is darker or lighter I run the "auto gamma adjustment". Then make more test pages. Charge units causing light/dark streaks are very common with the C6500. As long as 0 is white, 255 is solid for each color, and the halftone looks smooth that is the best the copier can do.
                If the colors are still off even though the test pages look good, then it needs adjusted through the program or print driver. Depending on the program you can dial in colors or change the RGB->CMYK conversion. I've had the best luck with turning on "vivid colors" setting in the driver.
                The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred Hoyle
                • methogod
                  • Dec 2008
                  • 921
                  other way to further isolate is to mix colors...
                  yellow and cyan @ 70% each - should be a solid green
                  cyan and magenta @ 70% each - should be a solid purple
                  yellow and magenta @ 70% each should be a solid orange
                  any of the CYMK colors show through you have some issues in a single color.
                  If your not trained on a C6500 or have alot of practical experience the machine can be a bitch.
                  • dagoof
                    Still learning...
                    • 220
                    I think it's the first post he's ever bothered to read without posting a stock reply peddling manuals
                    True, I'm not a tech (unfortunately I can't change my profile description, happy for mods to do that) but, as I'm ineligible for contract, I'm forced to learn, and mostly get by thanks to helpful board members which I really appreciate. I just want to be as knowledgeable as I can be.
                    So, thanks for all the helpful replies. I've cleaned the reg assy before (have plenty of experience there from the c500 and have taken care not to damage) but that didn't help. The drums/coronas are all new, but the dev is nearing the end, so I'll replace that soon. Thanks for all the suggestions, plenty of info there to help diagnose.
                    • JustManuals
                      • Jan 2006
                      • 9838
                      It's obvious that you don't spend much time here, besides giving away FREE manuals to the people who help out here on a regular basis, if someone asks nicely, I take the time to look up and error code and post it.
                      • methogod
                        • Dec 2008
                        • 921
                        No judgement. You need to make a living.
                        • JustManuals
                          • Jan 2006
                          • 9838
                          Yes, thank you and this is how I make my living. I chalk my time spent here as 'marketing'
                          • dagoof
                            Still learning...
                            • 220
                            And what exactly has taking pot-shots at me got to do with your marketing? How does that help you earn a living
                            I've spent plenty of time on here but seldom post as I'm not in a position to advise. I too am trying to earn a living by learning to use my machine to it's best use and, thanks to some helpful people, I can mostly do that. I'm not really interested in this keyboard warrior stuff either, just want to learn. It's a public forum, so I don't really know why you've got a problem with this...
                            • Itsthepaper
                              Supervisor
                              • Dec 2007
                              • 91
                              Remember when you take out the color registration unit, don't just wipe the sensors. Take them off the unit and pry of the clear plastic cover and clean them off good. They load up with toner behind those clear plastic covers and would mess you up.
                              Love the Job Love the Work.
