C252 blank magenta copies
  • repeatcopiers
    • Sep 2008
    • 591
    I have a C252 in the field that gives a blank magenta copy. We replace the magenta drum unit and still same issue.
  • wseyller
    • Sep 2012
    • 1129
    Check to see if laser from write unit is blocked.
    Sent from my XT875 using Tapatalk 2
    • MAD0RAM
      • Oct 2012
      • 81
      Re: C252 blank magenta copies
      Or the primary transfer roller may be out of place on the transfer belt.
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        if none of the above first, it will be the HV board, then failing that the PWB-M
        (assuming some d/h hasn't damaged the flat ribbon cable to the laser relay board when changing a main motor in the past)
        • wseyller
          • Sep 2012
          • 1129
          I would print some magenta rich pages and stop the machine half way to see if the image is on the drum or not. That could eliminate the drum and write unit.
