bizhub PRO C6000 stapling problem
  • edin
    • Sep 2011
    • 4
    we have bizhub PRO C6000L with booklet finisher FS-612.
    Last few days we cannot use stapling option because staplers just touch the paper and not break through the set of paper.
    We have changed the both stapling units but we didn't get any improvements.
    Doe's anybody have similar problem?
  • methogod
    • Dec 2008
    • 921
    Re: bizhub PRO C6000 stapling problem
    Subject:
    Stapling jam when a FS-531 or FS-612 finisher is connected directly to the main body.
    Description:
    FS-531/FS-612, stapling jam.
    Solution:
    CAUSE: Firmware bug.
    SOLUTION: Please install attached special firmware version GC1-10 on the finisher.
    let me know if you need it or you can grab it (TAUS1002277EN00)
    • edin
      • Sep 2011
      • 4
      I cannot find TAUS1002277EN00 on Info Hub so please send me this FW as attachment on my e-mail (edin.smajovic@hotmail.com).
      Thank you in advance.
      • edin
        • Sep 2011
        • 4
        Originally posted by methogod
        Subject:
        Description:
        Solution:
        @methogod,
        first of all I wish you happy New Year, and very well health and lot of happiness!
        Thank you again for answer, but this FW is not solution for this problem.
        Problem is obviously with staple position adjustment, so I made order for service Jig, and now I'm waiting.
        Best regards
        • sanimir
          • 183
          And wait for him 21 days?
          pozdrav Edin
          Originally posted by edin
          @methogod,
          Best regards
          • andreas
            • Sep 2009
            • 3
            Ciao bisogna regolare le cucitrici con le dime originali
            • DigiMan
              • Jan 2013
              • 262
              Hello,dont know if you found the solution already but i had the same problem a year back or so,you could hear the staplers touching the paper but no stapling to be found.
              All i did was enter the service mode found the the DIP SW for each stapler and made it punch manually 5-6 times(had the FS door open with an interlock while having 2-3 paper put in the stacker).After some failed attempts it started stapling again.
              Hope i helped.
              I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
              • edin
                • Sep 2011
                • 4
                Jig for staplers position adjustment is solution for this problem. It is stapling again.
                Thanks for help to all of you guys
