KM 751 C-6708
  • doug94550
    • Dec 2011
    • 138
    KM 751 C-6708
    Hi Guys,
    This is a follow up to my previous post on this problem.
    Once again, I have a 751 with a C-6708.
    When the machine initializes, the scanner runs to home and then moves out to the white reference.
    When the lamp illuminates, it actually flashes on and off about 6 times.
    If I reach back and push down the plunger as if the ADF were closed, the lamp illuminates and stays illuminated, no flashing.
    This is the cause of the C-6708.
    I have replaced the Inverter and the driver board.
    The problem began after the Print Driver chip was installed. For what I can see, the Print Driver chip is essentially a jumper to enable the Print Function.
    I was able to get the Firmware and was ready to Flash the machine but in order to do this I have to go through the Service Mode, System 2, ISW.
    And here is where I hit the wall.
    I can enter Service Mode just fine. When I get there, in the upper right corner, it shows the C-6708 code.
    From that point, when I try to select anything, the machine just throws up a "Please Wait" next to the code and it just sits there.
    I can reset the code, however, when I do, the machine initializes again, the lamp flashes, and the code returns.
    Is the a backdoor way to bypass this code and Flash the machine?
    Any and all ideas gratefully appreciated.
    Have a Happy New Year Everybody!!!
    Doug
    Oh Yeah, one more thing. Does anyone have the part number for the system board?
  • JustManuals
    • Jan 2006
    • 9838
    Re: KM 751 C-6708
    This Parts & Service Manual can now be purchased for $12.77 (11.00 this week) and downloaded immediately after payment from:
    Paul@justmanuals.com
    • Albonline
      • Sep 2008
      • 1151
      Re: KM 751 C-6708
      from the bookCCD board (CCDB)
      Exposure lamp (L1)
      did you try removing the ic chip?
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        Re: KM 751 C-6708
        Not that its all that relaited but recently i had a persistant AGC adjustment malfunction on a bizhub 421, it turned out to be a failed CCD. Also make sure you haven't inadvertently damaged the ribbon cable to the CCD while the back was off and that its seated correctly with no damage. (if there is one, i cant remember)
        • DelawareJim
          • Jan 2008
          • 65
          Re: KM 751 C-6708
          On that model, isn't there 2 sets of slots where the IC-208 chip can go? I wonder if you've got the chip in the correct socket. Take the chip put and see if your problem goes away. When you put that chip in, make sure it is inserted in the correct slots and make sure its not upside down. Damn, could they make that thing any smaller?
          • methogod
            • Dec 2008
            • 921
            Re: KM 751 C-6708
            Or you have the older 600 IC CHIP...
            possible..
