bh160 incorrect t/c
  • JR2ALTA
    • Feb 2010
    • 2033
    [CQ] bh160 incorrect t/c
    message of incorrect t/c (toner cartridge) swapped oem drum and toner, cleaned as needed. still get message periodically
    laid back customer doesn't mind reseating, or rebooting but I'd like to get a handle on it if anyone has seen this.
    thanks in advance
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: bh160 incorrect t/c
    From memory, the official method is to hold down the stop button while powering on the machine to clear this error.
    However, when i see it, I also ensure the contacts are clean on both the "T/C" and the machine, and just at the point the cartridge lowers when closing the door, i stop closing the door and push the "T/C" downwards good and proper manually and then close the door.
    Also make sure at idle the memory is at 100% anything less after a fresh power on and there are no faxes stored in memory means the memory contains corrupt fax data and a DRAM clear is required. (more prevalent on the F2900/3900, but also occurs on these and everything up to the B163 series) Strange behavior results from this alone.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • Hansoon
        • Sep 2007
        • 3385
        Its this terminal getting dirty inside and/or having warped contacts. Just solder a resistor as shown in the picture and machine believes that a unit is present.
        Hans
        โ€œSent from my Intel 80286 using MS-DOS 2.0โ€
