C650 back grounding magenta
  • rasman67
    • Jul 2025
    I have a BH C650 that is back grounding magenta on every copy. I have replaced the IU with no change. The whole page is magenta see the attachment. If anyone could help I would appreciate it.
    Thanks in advanced
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Re: C650 back grounding magenta
    What do the internal test prints for each color look like in the service mode?
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • rasman67
      black is fine but all other colors have the same back ground.
      Thanks again
      • Kidaver
        Ghoulscout
        • Apr 2011
        • 912
        Check your values in Level History 2 and see if they are all in a similar range. If one is way off which would likely be the magenta value and you've replaced the IU, then you'll prolly look at replacing a board. If they all seem fine you are probably looking at a PH unit.
        • KM7155
          • Aug 2008
          • 146
          is there any warning sign on the touch screen i.e P8, P21....
          i have this problem on C352, the problem is the ribbon cable from drive board to the main control board
          faulty.
          • Synaux
            • Mar 2012
            • 1224
            faulty.
            I was about to suggest checking the ribbons/cables. You might be looking at a board replacement though...
            • Itsthepaper
              Supervisor
              • Dec 2007
              • 91
              If all else fails replace HV.
              Love the Job Love the Work.
