FYI, duplex jamming on C224 - C554
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    The swing out duplex door rollers are clutch driven off the main drive unit - they used to have their own motor in previous versions of this engine, ie, c360 series.
    If you find the duplex rollers simply don't turn when trying to duplex and you have consistent jamming at the top duplex roller - replace the duplex drive clutch in the rear of the machine.
    Load check is a waste of time, because just a bit more current is delivered to the clutch in load check than in normal operation and it WILL lockup, making you pull your hair out wondering WTF is going on.
    Fortunately, i have plenty of hair left.
    • 23009
    Re: FYI, duplex jamming on C224 - C554
    Alas, I don't have much hair to spare. Thanks for sharing. =^..^=
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      I assume the extra current available to successfully lockup the duplex clutch in load check mode is because absolutely nothing else is being powered at the same time, unlike in normal operation mode.
        • 23009
        There's some logic to that. What jam codes? =^..^=
        • jrf
          • 142
          Thanks for info
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            I don't recall the jam code, unfortunately. But was along the lines of not meeting the sensor after the duplex rollers in a timely fashion.
            The rollers don't even turn - you can watch the shaft with the front door open and switch tricked.
            This machine only had 250 pages on the clock and it looks like they're slopping too much grease around in the drive units (again)
