KM bizHUB 421 has Horizontal lines on all prints/copies ???
  • gerryhuerta
    AccService
    • Jul 2009
    • 198
    So this machine is giving us horizontal lines accross each copy or print. Just about 2-months (28k prints) ago we replaced the entire drum unit but the tech DID NOT reset the drum counter. Up until recently we had been getting foggy background on the drum followed by the well known C-2801 TCR output Errror.
    We have reset the C-2801 error but now we are getting these horizontal lines (like attached) what should be my next step..? We are posting here just before thinking to replace Developer????
    Thanks for all your help.
  • Shadow
    PHD in Sh!t Disturbing
    • Sep 2011
    • 455
    Re: KM bizHUB 421 has Horizontal lines on all prints/copies ???
    check the cleaning auger and gear drive for the drum unit.
    it looks like its packing up because there is a broken or damaged gear.
    $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
    • Synaux
      • Mar 2012
      • 1224
      Perhaps a damaged tranf belt gear too?
      • minimerlin
        • 851
        Looks to me like either a dirty grid or drum or grid charge is incorrect due to count not being reset. Did you change the drum when you changed the drum assembly? Have a look at the settings on the machine.
        Please do not PM me without asking first.
        • mo0651
          • 1054
          Clean or replace the main charge wire and the transfer/ sep wires.
          • gerryhuerta
            AccService
            • Jul 2009
            • 198
            All this is very helpful.. On my way with parts rightnow to check this out. Will update you soon Thanks again to all...
              • 23009
              I'm with minimerlin and mo0651. The lack of crisp edges on these lines, the way they waver, and the way they peter out indicate to me that there is lint in the primary grid or on the charge wire. =^..^=
              • nmfaxman
                • 1702
                I am thinking Blade flip.
                Run 10 sky shots and see if it goes away, or turn the drum unit by hand and see if you get the marks.
                Charge arc would not leave a set interval and a broken gear would happen more often.
                Just my thought.
                • gerryhuerta
                  AccService
                  • Jul 2009
                  • 198
                  minimerlin and the rest of you where correct. The charge grid wire was dirty and needed simple cleaning.. The original error threw us off in the wrong direction but I still dont know how we missed that.. Thanks to all...
                    • 23009
                    Congratulations. =^..^=
                    • Synaux
                      • Mar 2012
                      • 1224
                      Glad to hear you got it sorted out
                      • brent
                        • Nov 2008
                        • 1214
                        glad you got it. this machine is easy to see that. corona wires and grid.
                        glad you got it fixed
                        brent
