konica minolta c351 question
  • brent
    • Nov 2008
    • 1183
    kind of a wierd thing happened today. I went and check in utility mode. to the consumables. then I replaced the transfer belt and fuser. then I tried to go back into to utility. and I could not get it to go into utility at all. turned off and on a couple times. then unplugged. nothing.. so that means I can't go into into any counters or functions or admin mode. nothing. I just have no clue what I did. anybody have this happen to them? by the way. the copier works fine prints fine etc.
    any thoughts>?
    brent
  • RRodgers
    • Jun 2009
    • 1950
    Re: konica minolta c351 question
    any thoughts>?
    brent
    Job stuck. Is it a fax as well?
    • brent
      • Nov 2008
      • 1183
      It is not a fax
      • Avskrap
        Partner in crime
        • Jul 2011
        • 160
        If there are any P-codes you won't be able to get into the menus. Check and correct any and all errors or warnings and you'll be able to get going again.
        • brent
          • Nov 2008
          • 1183
          There are no p codes. Thy is why this is so condusinf
          • Solotime
            • 223
            Same Issue Here...Did you get yours resolved?
            • Alex1
              • Oct 2012
              • 285
              any thoughts>?
              brent
              I had the same problem with my C351 but the funny thing is all my digital counters reset back to zero, while the analog counter was reading 190k. Is the utility button gone faulty?
              • Avskrap
                Partner in crime
                • Jul 2011
                • 160
                Resetting of the counters? Sounds like an NVRAM failure.
                I've never liked these boxes...
                • Alex1
                  • Oct 2012
                  • 285
                  I don't like them my self. Unfortunately you have to cater for all. Major upgrade with the C252, 352 onwards.
