C0070
  • simba28
    • Apr 2012
    • 1
    [Error Code] C0070
    hi all,i have bh 163 and its showing error C0070
  • avecosat
    • Jun 2012
    • 305
    Re: C0070
    Toner bottle is wrong positioned or the motor toner group is bad working .
    • Spidula
      Konica Minolta Technician
      • 83
      Re: C0070
      Check to make sure the correct toner is installed. I had exact same problem today, and the customer had stuck the wrong bottle in. The extra notches on the bottle were jamming in the bottle section.
      • JustManuals
        • Jan 2006
        • 9838
        Re: C0070
        Paul@justmanuals.com
        • brent
          • Nov 2008
          • 1213
          Re: C0070
          it would be nice to know if the advice given was used to fix the problem.
          I wish we could make it so you had to report back.
          if it fixed the problem. great. we need to know. if it did not. let us give more advice.
          sorry. off my soap box now. and back to fixing my own machines..
          brent
          • mick o connor
            • Jan 2013
            • 9
            Re: C0070
            error is toner supply bottle not stopping in home position,best fix is to change toner supply hopper, approx 150 euros.
            regards Mick
            • juve
              • Dec 2012
              • 86
              Re: C0070
              regards Mick
              the problem is probably because the client tried to twist the toner bottle,all you have to do is dis assamble toner hopper and you will find that the spring on the home position actuator is out of place.re insert in place.if you are unlucky you may find also a broken gear at the toner motor(but this is not normal)
