hi all,i have bh 163 and its showing error C0070
C0070
Tags: None
Re: C0070
Paul@justmanuals.comComment
Re: C0070
it would be nice to know if the advice given was used to fix the problem.
I wish we could make it so you had to report back.
if it fixed the problem. great. we need to know. if it did not. let us give more advice.
sorry. off my soap box now. and back to fixing my own machines..
brentComment
Re: C0070
error is toner supply bottle not stopping in home position,best fix is to change toner supply hopper, approx 150 euros.
regards MickComment
Re: C0070
the problem is probably because the client tried to twist the toner bottle,all you have to do is dis assamble toner hopper and you will find that the spring on the home position actuator is out of place.re insert in place.if you are unlucky you may find also a broken gear at the toner motor(but this is not normal)Comment
