Ld1, Ld2 offset adjust on bizhub 750
  • roniirawan
    • Nov 2008
    • 15
    Hi Friends,...
    can u all explain to me what is the meaning Ld1 , Ld2 offset adjust....
    Why the lightest image must on the reference line ? if dark image on the reference line what can cause to tcsb reading.
    what will happen if modified the gap of tcsb and drum ( close to the drum )...
    thanks all
  • Darren King
    copiertech
    • 652
    Re: Ld1, Ld2 offset adjust on bizhub 750
    It is for adjusting image density. If it is too dark on the printouts it will become over toned much faster than it would normally.
    Why would you want to adjust the position of the TCSB?
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • fishleg
        • Mar 2009
        • 426
        Thats good though isnt it the darker the more toner that is going onto the paper instead of back into the drum/dev unit. I always make it just so it fades just after the top line. Please correct my logic :P?
        • Darren King
          copiertech
          • 652
          The way I was taught during training is that the grid should be almost invisible as it crosses the first line. The first line is the one closest to the grid pattern.
            • 23009
            And this helps control over-toning? Or toner dumping in the transfer/separation? =^..^=
