Enable Graphic Art package on Fiery s300?
  • sanimir
    • 183
    How to enable Graphic Art package on Fiery s300?
    I have no money for the manual-I live in a poor country
  • RRodgers
    • Jun 2009
    • 1947
    Re: Enable Graphic Art package on Fiery s300?
    Buy it. It't been a LONG time but I think it's a dongle. I've never seen a Fiery with one.
    • sanimir
      • 183
      I have dongle and install package.
      After restart no package on config list and no in cws.
      • RRodgers
        • Jun 2009
        • 1947
        You put the cd in and did the update right? Did you leave the dongle plugged in?
        **edit**
        Found this in the data base,
        " A dongle is required for to enable the feature before using this CD. Insert the dongle prior to selecting the update option from the CD menu. "
        • sanimir
          • 183
          [QUOTE=RRodgers;335767]You put the cd in and did the update right? Did you leave the dongle plugged in?
          Yes RRodgers
          • sanimir
            • 183
            [QUOTE=sanimir;335768][QUOTE=RRodgers;335767]You put the cd in and did the update right? Did you leave the dongle plugged in?
            Any help for this situation RRodgers
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              Is the dongle new, or did you get a used one from somewhere?
              The dongle can only be used once, as I recall.
              Used ones are normally useless on most models. (It's been a loooong time since I've worked with an S300, as well.)
              • sanimir
                • 183
                new one
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  The dongle comes with an install CD, and printed installation instructions.
                  Put the dongle on. boot from the CD, and follow the directions on screen.
                  • sanimir
                    • 183
                    Please read post no4:
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      Try reinstalling system software.
                      • RRodgers
                        • Jun 2009
                        • 1947
                        Only thing I can think of off the top of my head is your are missing a patch or an update or something.
                        • oxident
                          • 74
                          Is there any chance to get a copy of this CD? Just want to know what exactly this CD does. As far as I know, the required software is already part of the Fiery System Software ... so I'm wondering why you need this CD at all
                          • jotunn
                            • 613
                            @oxident
                            There is HASP dongle, and installation CD - during Fiery option installation process you have to put a dongle into USB (or LPT in legacy Fiery's) port, then you have to boot fiery from install CD.
                            A program on CD checks:
                            - if this is a Fiery at all
                            - if this is a proper Fiery
                            - currently installed options
                            - if a dongle is installed
                            - if this is a valid dongle
                            - if option related to dongle is not yet installed
                            Then asks you if you want to enable option, and if you accept, makes proper modifications in BIOS.
                            I did it already... everything you thought about...
                            • oxident
                              • 74
                              Interesting details, thanks for that!
                              One thing remains unclear to me: What to do if you have a headless (non-FACI) Fiery? Can you start the update process remotely?
