Enable Graphic Art package on Fiery s300?
  • sanimir
    • 183
    #16
    You update via rip lcd
    • oxident
      • 74
      #17
      Re: Enable Graphic Art package on Fiery s300?
      But you still need another machine for the installation CD?
      • sanimir
        • 183
        #18
        This machine have cd. Almost all external rip have cd/dvd
        • jotunn
          • 611
          #19
          No, let me clear that.
          There are two kind of Fiery controllers:
          - embedded - without CD-ROM, without built-in LCD and _without_ possibility of installing options
          - standalone - with CD-ROM (or DVD-ROM in newer Fiery controllers), built-in LCD, and possibility of installing various options
          With embedded controller you can communicate through a copier touch panel - after installation of such Fiery controller additional menu is displayed on screen. There is almost no possibility to "extend" those Fierys, you can add a memory, install newer OS version (if there is any, through network/USB with special app, or locally with pendrive), or install patches, and nothing more...
          Standalone Fiery has built-in small LCD for configuration and also shows additional menu on copier screen. You can install software (and options) through local CD/DVD drive.
          • kronical
            Kronic Copier Ninja
            • Nov 2009
            • 230
            #20
            You certainly can add options, pull the rubber plug out of the usb port. you can also use usb cd/dvd drives.
            The dongle goes into the fiery, not the workstation.
            • oxident
              • 74
              #21
              Except for the Impose (aka DocBuilder, aka SeeQuence) function. This dongle goes into the workstation.
