Minolta 2010 cs pro Jamming @ Drum Unit
  • sagar4
    • Dec 2012
    • 127
    I have a minolta 2010 CS Pro jamming on and off at the drum. Seems like static when it sticks to the drum. I can pull the paper right off. It seems like it clings to the drum. I was thinking about replacing the conrona assembly since the one on the copier looks worn out. Every thing else looks fine. Any suggestions. Thanks
    "Broken again"
  • Darren King
    copiertech
    • 652
    Re: Minolta 2010 cs pro Jamming @ Drum Unit
    Possibly the registration clutch is failing. Clean or replace.
    Darren
    • mo0651
      • 1054
      IS THE SEPARATION WIRE IN THE UNIT BROKEN? Is the paper folded and jammed or just laying in there?
      • sagar4
        • Dec 2012
        • 127
        Wire is not broken. And yes it folds slightly and sticks to drum. Not all the time maybe evey 20th sheet or so. That's why I was thinking the corona assembly not functioning correctly and static builds static up.
        "Broken again"
        • mo0651
          • 1054
          Nope sounds like clutch.
          • sagar4
            • Dec 2012
            • 127
            Okay clutch it is. By any chance would you know the part number. Thanks
            "Broken again"
            • Hansoon
              • Sep 2007
              • 3391
              No need for new. Soak it and wash it out with brake cleaner than blow dry with compressed air. Works like new for sure.
              Hans
              • sagar4
                • Dec 2012
                • 127
                Okay thanks every one for the information.
                "Broken again"
                • johnnymeg
                  • Mar 2012
                  • 11
                  If that does not work try the solenoid for the drum pick off. It has been awhile but I remember that causing a similar issue.
