KM Bizhub C550 Unresponsive screen and buttons
  • mntech
    • Aug 2010
    • 250
    Customer had a power outage, after power came back on, the machine is no long responding.
    -Normal boot will get to the main copier screen, hard keys and touch screen will not respond, also turning off the control panel power will do nothing, screen just stays on.
    -Customer was not able to print, I did not check to see if the machine could be pinged or access the web interface.
    -With HDD disconnected, displays error C-D004 but still no response from any hard/touch buttons. Cannot access service mode.
    -Holding Utility during power on phase to get to trouble reset will show the black circle in top right corner, but after a min the circle goes away and machine freezes at Konica Minolta screen and will not make it to "trouble reset" (same thing happens with or without hard drive plugged in)
    -All fuses on power supply board are good
    -Tried another blank hard drive, same results as above.
    Saw another post on here that looks like firmware fixed the problem, although another tech told me they had the same problem from another C550 and it was the power supply board that fixed the problems(his machine had multiple blown fuses tho, board was replaced and worked)
    Do you think firmware would help or should I just go right for the power supply board?
    Thank You!
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: KM Bizhub C550 Unresponsive screen and buttons
    I would try firmware then power supply.
    • MAD0RAM
      • Oct 2012
      • 81
      Try the memory on the MFB.
      • kingarthur
        • 1383
        had a similar problem on a C451...it was the RAM, used one from a C203
        • mo0651
          • 1054
          Just had a c253 that had the ready screen up but would not do anything. Reseat connectors to the screen and boards and away it went. When we had memory chip problem, the screen was blank but the lights were on. (i.e. the circle around start button)
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
            • mrwho
              Major Asshole!
              • 4299
              I believe there's an NVRAM reset utility that could help you in those cases.
              Mascan42
              Ibid
              • Synaux
                • Mar 2012
                • 1224
                Of course try the firmware before replacing a board...
                Mrwho is correct, there is a NVRAM reset that would probably be the most useful.
                I am fairly certain you want "C550_A00J0Y0-F000-GCQ-J8(00)."
                You can check the memory with modules from another machine or put the modules in a laptop and check with memtest86. If I remember correctly, you cannot have a module in the top slot in the mfp board (just remember which DIMM was originally empty and keep it that way
                Good Luck.
                • JustManuals
                  • Jan 2006
                  • 9838
                  I have the NVRAM reset tool. Contact me in email if interested.
                  • mntech
                    • Aug 2010
                    • 250
                    Fixed.
                    Ended up being the RAM dimms on the control board.
                    I tried those before I did firmware or power supply, ram dimms came from a parts machine same model.
                    Thanks everyone!
                    • mrwho
                      Major Asshole!
                      • 4299
                      Originally posted by mntech
                      Fixed.
                      Thanks everyone!
                      Thanks for the heads up! Will keep that in mind if I ever come across that problem. Reps to you!
                      Mascan42
                      Ibid
                      • EarthKmTech
                        Step aside, noob
                        • May 2009
                        • 2139
                        I've had that before on the c451.
                        its quite common, for some reason that ram likes to fry - having said that ive had it die in old laptops too so it aint km's fault - for a change.
                        • mntech
                          • Aug 2010
                          • 250
                          I just ran into an unresponsive bizhub c451
                          Machine would come to the main screen and after about 15 seconds the screen would freeze. Screen, hard buttons, and panel power button wouldn't respond. I could access trouble reset.
                          Problem went away after I rebooted machine with network cord disconnected.
                          I deleted all pending print jobs from everybody's computer, but once I plugged the network cord back in, the data light wouldflash and machine would freeze. I ended up setting the machine to a new IP address and updated everyone's print queue port. So there was either a computer on the network I missed that had a corrupted print job or something on the network conflicting with printer.
                          long story short, be sure to disconnect network first before attempting firmware, ram, or power supply
