bizhub c252 transfer belt fuse
  • sn00kerpaypal
    [Electrical] bizhub c252 transfer belt fuse
    Can anyone help with changing the above and tell me size and rating the fuse is
    Regards
  • Imsdal
    • Aug 2009
    • 111
    Re: bizhub c252 transfer belt fuse
    80 mA.
    • juve
      • Dec 2012
      • 86
      Originally posted by sn00kerpaypal
      can anyone help with changing the above and tell me size and rating the fuse is
      regards
      80ma fuse.on the side you have to remove a small screw and an e clamp ,remove cover(also there is a spring)put the fuse and re assamble.
      • JR2ALTA
        • Feb 2010
        • 2033
        yea what the hell is that "spring" for?
        • minimerlin
          • 851
          It`s just there to be a pain in the a**! I think it is supposed to be an earth connector but if it is missing I never bother about it and no problems occur.
          Please do not PM me without asking first.
          • juve
            • Dec 2012
            • 86
            infact i also remove that stupid claw in the middle,better without it,when a big paperjam happen this f##ken claw turn around and damage the belt,so better without it,
            • Avskrap
              Partner in crime
              • Jul 2011
              • 160
              If the claw is missing or busted, you'll get a bunch of papers stuck in the cleaning unit for the transfer belt.
              I've seen this happen quite alot, this friday I cleared out five papers stuck in the CL unit on a C353.
              I usually loosen the screws for the holder and flick in back in to place if the customer doesn't notice the "mustache". If they do, new belt.
              • juve
                • Dec 2012
                • 86
                in my case,even with the claw there,if the paper used is humid the paper will jam and go underneath the claw
                • ronanl
                  hi where will I find the fuse on the transfer belt?
                  • kingarthur
                    • 1385
                    In the fuse holder?....
                    • ronanl
                      thanks for that I have found it, would you know if it is possiable to reset the black fuser as it is at 20% even thought the machine has been used for less than 20k copies. thanks again for your help
                      • rrrohan
                        • Sep 2011
                        • 1977
                        i have always wondered about that.
                        i was finding on the low volume machines that claw alwyas leaves a dent.
                        So you have removed it without paper curling back into belt?
                        Might start doing this
                        • juve
                          • Dec 2012
                          • 86
                          yes it worked.obviously i found that if the paper is too damp,with or without it,it will still enter in belt,so better without it.and if a paperjam like this happen there will be no damages because of this claw,just remove the papers from belt
