Bizhub c353
  • wtomes
    • Jul 2025
    [Misc] Bizhub c353
    I have Bizhub c353 control panel doesn't work at all no buttons work and touch panel doesn't.
    Start button light is red on.there is no error code on the display and display is normal. The touch panel will not let
    me reset the machine with the trouble reset procedure. This happen after a copier jam no one could find.
    can not get into maintence modes. Any ideals fellow techs
  • JustManuals
    • Jan 2006
    • 9838
    Re: Bizhub c353
    Paul@justmanuals.com
    • tervel12
      • Dec 2008
      • 65
      Re: Bizhub c353
      The hard drive may have failed. Try disconnecting it and then see if you can get into service mode.
      Also, the firmware or NVRAM may have been corrupted. Try reflashing the MFP with the latest firmware.
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        Re: Bizhub c353
        try disconnecting the network cable.
        I HAVE had on 2 machines in 1 location such bizzar activity after lightning damage to their network switches, once they were replaced the machine were fine on the network again.
        • wtomes
          Re: Bizhub c353
          Thanks guys I got it fixed it was a bad stick of ram.
          Warner Tomes
