Minolta EP2130 Drum Unit
  • Neil
    Greetings to All,
    Well, I must confess, I\\\'m not a copier repair tech. I make my living in the supplies end of the business. But a customer has given me the copier mentioned in the Subject line, and it seems to be in perfectly good working condition, except for the drum unit has reached the maximum copy count and shut the machine down. Now I don\\\'t want to buy a new drum unit (too expensive even at wholesale), and I suspect that is the reason my customer didn\\\'t want to continue using the copier also.
    Anyway, I wonder if there is a way to reset the copy counter on this machine, or the drum cartridge, so I could continue to use it past the recommended copy count. I have done this on copiers by other makers, and been able to extend the life of a used copier.
    Regards,
    Neil
  • eg101
    • Jan 2005
    • 131
    Re:Minolta EP2130 Drum Unit
    There\'s a small fuse on the imaging unit which resets the I U counter. I don\'t know the value of it but if you can jump it and turn on the copier for a few seconds, it should reset.
    Make sure you remove the toner bottle before doing this or it will add the whole bottle.
    • Bazal
      go to www.smarka.com look in the minolta copier tech tips and it tells you how to reset the image cartridge
      • John T
        Smarka has the info to reset. I usually get another 2-3000 copies from these after resetting. Precisionroller.com has the starter, fuses, and drums to rebuild the I/U. Drum is work, but just starter has worked fine for me. Don\'t bother putting the fuse in the I/U unless youre taking it to a customer. Just follow the jumper instructions using the main board contacts. I have just used a wire to jump in the past, but I am more cautious now and the fuses are cheap enough.
        Good luck.
        • techsxge
          • Jan 2022
          • 660
          Re: Minolta EP2130 Drum Unit
          Hello there
          • Synthohol
            Certified Konica Expert
            • 5814
            • tsbservice
              Field tech
              • 8003
              Originally posted by Synthohol
              Agree but give him a credit for breaking the record. I mean this is like 17 years old... wow 😅
              • zayonc
                • Jan 2022
                • 49
                it's like a 1967 ford mustang
                • KMFLT3CH
                  • May 2017
                  • 230
                  Originally posted by techsxge
                  Hello there
                  • techsxge
                    • Jan 2022
                    • 660
                    Originally posted by KMFLT3CH
                    • techsxge
                      • Jan 2022
                      • 660
                      Imagine the Threadstarter just checking his email and being confused why there are star wars pics in his email archive
