How to remove the HDD from a Konica Minolta Bizhub 362 copier
  • myxer1234
    • Feb 2013
    • 27
    Need to remove the hard drives from a bunch of these copiers going back to lease company. Never saw one before but I am Ricoh trained.
  • Luther
    • May 2006
    • 682
    Re: How to remove the HDD from a Konica Minolta Bizhub 362 copier
    models would help
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      it is either mounted on the system pwb which requires the Whole back panel taken off then the steel cage taken off.
      Or it is mounted under the scanner on the right side. take upper rear cover off and disconnect three plugs then three screws on the right side and slides out the right side.
      If you ask Manuals for you he may have the books for a reasonable price.
      • JustManuals
        • Jan 2006
        • 9838
        These Parts & Service Manuala can now be purchased for $12.77 and downloaded immediately after payment from:
        Paul@justmanuals.com
        • myxer1234
          • Feb 2013
          • 27
          Thanks for the help.
          • emujo
            • Jun 2009
            • 3009
            FYI, the built in HDD overwrite software will clean the HDD to DOD EAL 3 standards...this is pretty decent and makes most IT reps comfy...I mention this because you say you have to remove the HDD. The leasing company wants the MFP back in the same config that it was sold. Your company may be charged for the missing drives..this cost should be passed to the customer if they are adamant about removing the drives. Emujo
            • myxer1234
              • Feb 2013
              • 27
              Originally posted by emujo
              FYI, the built in HDD overwrite software will clean the HDD to DOD EAL 3 standards...this is pretty decent and makes most IT reps comfy...I mention this because you say you have to remove the HDD. The leasing company wants the MFP back in the smae config that it was sold. Your compnay may be charged for the missing drives..this cost should be passed to the customer if they are adamant about removing the drives. Emujo
              Customer needs HDD
              wher is it I can't find it
              • kingarthur
                • 1341
                as far as i can remember it's mounted on the PCB on this model, however it is an option & therefore may not be fitted
                • Darren King
                  copiertech
                  • 652
                  If this machine has a hard drive it will be mounted to the MFBS board. But as kingarthur said, it was an option so may not be there. Go into user mode and print a configuration page, it will tell you.
                  • juve
                    • Dec 2012
                    • 86
                    Originally posted by myxer1234
                    Customer needs HDD
                    it is exactly as mr spoke told you,underneath the scanner,do as he told you and it will slide out easy
                    • juve
                      • Dec 2012
                      • 86
                      remove right cover of scanner ,remove 3 screws,remove back cover of scanner,disconnect 3 connectors and slide out
