Print Quality Issue C253
  • habik
    • 2013
    Hi Guys anyone had similar problem ?
    So far changed Bk IU, lasers and done firmware.
    See attached pdf page 2 shows it very well!
    S20C-413020417290.pdf
    Firmwares HERE
  • JustManuals
    • Jan 2006
    • 9838
    Re: Print Quality Issue C253
    This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
    Paul@justmanuals.com
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      either failing ram or its the mfp board.
      that is image data corruption, it was never going to be an imaging unit or a laser
      1 free thing to try first of all is "initialize and stabilize" and see if any difference is made, if not, return to line one of my post..
      • habik
        • 2013
        Nice one, will give it a bash tomorrow cheers for that !!
        Firmwares HERE
        • mo0651
          • 1054
          Did you reseat the ribbon cables on the boards? just to see if something changes.
            • 23010
            Have you considered transfer belt cleaning? It might be simple. =^..^=
            • habik
              • 2013
              Problem Solved . Tried RAM modules (Both) DID NOT WORK
              Changed MFP Board and it worked magic.
              Thanks EarthKmTech!
              Firmwares HERE
