minolta dialta developer is falling
  • nilsonmorales
    • Jul 2025
    in the transfer,sep. area i change developer new and the problem persist ,each copy exit with developer tnx in advance
  • nilsonmorales
    sorry dialta 650
    is the model
    • Speedy
      • 30
      Is this a Di 650 or a Di 620?
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        There is a procedure to follow from the manufacturer. It's about 30 pages or so if my memory is correct. Follow that as it usually help. Also, make sure it's been PM'd and is adjusted properly. If all else fails, order a developer unit and a transfer/separation assembly.
        • nmfaxman
          • 1702
          Check the charge reconditioning lamp and blank erase lamp. Found a cold solder joint on the main board that turned on and off the charge reconditioning lamp. Too much residual charge on the drum will pull DV.
          Look at the drum with the front door open.
          Cheat the door and just on warmup you should see red lamps at 10 & 2.
          If one is missing, turn it on through 47 mode to make sure it will come on.
          • mitchl
            • Apr 2007
            • 501
            If you search this site for DI 650/ 7165 toner spewing you will find a comprehensive fix by a dealer in Wisconsin. If you follow the instructions to a T, it will take care of the problems you are experiencing which has to do with a lack of bias voltage, drum ground resistance, improperly set LD1, LD2, and grid voltage.......... Try it it works!
            • Rudi
              • Jun 2007
              • 251
              You Can Also Check Your Drum For Any Marks If The Drum Was Nicked It Arc To The Charge Corona Wich Then Gives You That Problem.
