C353 Boots up, touch screen freezes.
  • GHodgeCo
    • Feb 2013
    • 4
    [Dead] C353 Boots up, touch screen freezes.
    I have a KM Bizhub c353. The machine boots but then locks up & won't copy, print, fax...nuthin. I removed the HDD, had it checked, works fine. Checked ribbons, all seated. Pulled DIMM's, reseated. Reseated fax board. Reseated touch screen cable. All to no avail. Help! BTW, thanx to blazebusiness for all the help so far.
  • JustManuals
    • Jan 2006
    • 9838
    Re: C353 Boots up, touch screen freezes.
    Paul@justmanuals.com
    • Zeldaman
      • Mar 2011
      • 946
      Hi there!
      Load up the firmware again, this must solve your problem.
      Greetings...
      • Zeldaman
        • Mar 2011
        • 946
        Hi there!
        Reload the firmware, i think this will solve your problem.
        Greetings...
        • JSC
          Gimp
          • Dec 2006
          • 618
          If firmware does not help, I'd replace the ram next.
          The gene pool could use a little chlorine.
          • blazebusiness
            SanDiegoCopierRepair.com
            • 1252
            Just to elaborate on the problem-----spoke with GHodge via phone---origional symptom was a CD004 hard drive error code. Told him The HDD has either become corrupt or has failed..... User pulled his own hard drive and had it checked with a computer repair place who stated the hard drive tested good. When he reinstalled---no more CD004 code and machine almost completely starts up and tries to do grad adjust then panel freezes up/becomes unresponsive. As many of the Konica Minolta's boot from the compact flash card was going to pull a compact flash card from a machine in our warehouse to swap it out and see if that is the problem and found that the C353 is a bit different than the some of the other Konica's and does not boot from the compact flash----the compact flash card on this model is apparently only inserted to install firmware and then is removed from the machine. So, obviously, corrupt firmware may be the problem. We have access to the firmware.....I'll update it & post back here the fix for this.
            • GHodgeCo
              • Feb 2013
              • 4
              From reading other posts, I may need a couple new DIMMs, We'll see.?.
              • Avskrap
                Partner in crime
                • Jul 2011
                • 160
                My money's on the DIMMs. It's a common problem with these machines, faulty RAM, usually results in a black display but can also produce this type of problem.
                And yeah, no booting from flash cards, that's for the older ones
                • blazebusiness
                  • 1252
                  I'll swing by with those dimm's and we'll see if that fixes your problem my friend.
                  • GHodgeCo
                    • Feb 2013
                    • 4
                    Turns out it was the DIMM's. No firmware needed. We're back up & runnin'. I am a very happy man right now! Thanks for all your help blazebusiness.
                    • GHodgeCo
                      • Feb 2013
                      • 4
                      Thank you for the advice. It was the RAM.
                      • blazebusiness
                        • 1252
                        No problem, glad to be of service. A happy customer is a beautiful thing.
