Konica C353 Creasing Paper
  • whizkid75
    • Jul 2025
    [Jamming] Konica C353 Creasing Paper
    Hi everyone!
    I'm new here on the forums, but I have an important question. I have a Konica Minolta C353 printer/copier/scanner. My problem is with the scanning head. The auto document feeder on top that you can use to make copies is creasing the top left corner of the paper that I attempt to copy. The copy comes out fine; It's just that the initial document gets creased the majority of the time. Notice how I say majority. Sometimes it comes out just fine. I cleaned the scan head sensor, the inner wheels, and every component that may be interfering with the feeding process. I'm stumped at this point. Thanks for any help that you all can give!
  • habik
    • 2013
    Re: Konica C353 Creasing Paper
    Originally posted by whizkid75
    Hi everyone!
    If it makes "Dog Ears" you have something stuck in the feeder, if it feeds and its all wrinkly then you have to adjust the whole RADF . Get instalation Manual from Paul@manuals4you.com View Profile: manuals4you - Copytechnet.com
    Follow the instructions properly and you'll find the problem.
    If it still does not work for you, then you have not clean the sensors you mentioned correctly.
    Good luck.
    PS: I have found all sorts of junk in RADF's ..bluetag is the most common!!
    Firmwares HERE
    • whizkid75
      Thank you for the advice! I'll try this and get back to you.
      • scottybbb
        • Dec 2010
        • 126
        Check to make sure some of the mylars are nicked up or torn.
        • Lynn56
          TECH
          • Jul 2012
          • 21
          Try adjusting the hinges on the doc feeder. The feeder may be to high off the slit glass.
          • habik
            • 2013
            This hint was in the Install manual, surely Paul would be happier
            Firmwares HERE
            • Lynn56
              TECH
              • Jul 2012
              • 21
              Sorry Habik...I will try and stay out of your way in the future!
              • JustManuals
                • Jan 2006
                • 9838
                This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
                Paul@justmanuals.com
                • habik
                  • 2013
                  Up to you Lynn56,
                  Most of us go through a lot of manuals to find solution first. I sometime go through manuals to help others in here, as long as they tried to find solution themselves. I don't mean this in any offensive way.
                  If member is end user, then any manual is a very useful tool. Sometimes even User Manuals contain the appropriate information to solutions.
                  If member is a tech, saying I have tried this and that as per manual and it still did not worked out..then hints are always welcome, I think!
                  PS: I don't sell anything. Just advising.
                  Firmwares HERE
                  • whizkid75
                    Alright, good news everyone. Problem solved! I think it was actually just a dirt problem. I forgot to clean some stuff in the RADF's actual feeder slot. Did that and now every document is coming out clean and unfolded! Thanks for the awesome replies everyone.
                      • 23006
                      Well, it looks like you've loved up to your username. Congratulations. =^..^=
