Konica C451 finisher removal.
  • Lasersupplies
    • Jul 2011
    • 221
    Hi, i bought a konica c451 copier and when i recieved it i realised that they had sent out a finisher with it. My problem is i dont have the space for it and i was wondering if there is a possible way of removing thg finisher and still print to the copier? It throws up an error when i disconnect the finisher. Do i need any parts to convert it back to a standard copier?
    Many Thanks
  • kingarthur
    • 1369
    Re: Konica C451 finisher removal.
    What error are you getting
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
      Paul@justmanuals.com
      • Lasersupplies
        • Jul 2011
        • 221
        "The part indicated by (arrow) is open.
        Ensure that it is properly closed.
        The arrow indicates where the finisher was but i do not wish for it to be attached.
        • mrwho
          Major Asshole!
          • 4299
          Turn off the machine, unplug from the wall, disconnect finisher from machine and open it (slide to the left). Turn on machine and test. If it doesn't complain and if it copies OK, then you can safely* grab your screwdriver and take it off.
          Safely = With the machine turned off and making sure you don't dismantle anything you're not supposed to.
          Mascan42
          Ibid
          • Lasersupplies
            • Jul 2011
            • 221
            I have removed the finisher in that order but still recieve the error. Can this be used without the finisher attached to it? is there anything that needs to be disabled in the service mode?
            • 907tec
              • 434
              Did you unplug and remove the horizontal transport as well?
              • mrwho
                Major Asshole!
                • 4299
                You shouldn't need to disable anything. What finisher are we talking about? The one I'm looking at now is an FS-519...
                Mascan42
                Ibid
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2139
                  you arent removing all of the finisher, clearly.
                  by the sounds of things you have the internal finisher and are just unplugging the elevation unit. You need to also slide out the central section and unplug the big plug at the back of the machine.
                  If you have the huge boxy external finisher, your clearly leaving in the relay unit - just remove it and unplug it from the back of the machine. the finisher connector is a large gray AMP brand socket and plug with a black cable. The document feeder uses a similar connector.
                  • Lasersupplies
                    • Jul 2011
                    • 221
                    Hi, thanks for the tip guys. Do i need to buy a replacement part to slide over the metal area and if so how much would this be?
                    Many Thanks
                    • kingarthur
                      • 1369
                      you need an OT-503.....
