konica bizhub 200 crooked copy
  • DOE
    • Mar 2010
    • 258
    hi i have a bizhub 200 that is producing crooked copies. i have cleaned all rubber. happens from all trays, from platen and doc. any ideas thanks
  • JustManuals
    • Jan 2006
    • 9838
    Re: konica bizhub 200 crooked copy
    Paul@justmanuals.com
    • Hansoon
      • Sep 2007
      • 3391
      If it happens with internal print outs and if "crooked" means warped than have a look at the sync roller bushings. They could be worn.
      ADF or even scanner can also cause similar effects but with your rudimentary description its guessing from my side of course.
      Hans
      • Darren King
        copiertech
        • 652
        If prints are straight but copies are skewed, grab the left front corner of the scanner bed and lift up sharply. That will straighten out the scanner bed.
        Hope this helps
        Darren
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          I have had crap get under the reg roller and cause problems. I had one that had a piece of packing material rolling around under it for 4 years before it jammed itself in the roller.
