hi i have a bizhub 200 that is producing crooked copies. i have cleaned all rubber. happens from all trays, from platen and doc. any ideas thanks
konica bizhub 200 crooked copy
Re: konica bizhub 200 crooked copy
Paul@justmanuals.com
If it happens with internal print outs and if "crooked" means warped than have a look at the sync roller bushings. They could be worn.
ADF or even scanner can also cause similar effects but with your rudimentary description its guessing from my side of course.
Hans“Sent from my Intel 80286 using MS-DOS 2.0”
If prints are straight but copies are skewed, grab the left front corner of the scanner bed and lift up sharply. That will straighten out the scanner bed.
Hope this helps
DarrenComment
I have had crap get under the reg roller and cause problems. I had one that had a piece of packing material rolling around under it for 4 years before it jammed itself in the roller.The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
