Replaced K Imaging Unit - Still Print Quality Issues Bizhub C550
  • jeremyb503
    • Aug 2009
    • 38
    Hey folks, thanks again for the great advice in the past, I have another one for you here
    We are having a print quality issue, as you can see in the image below. I have replaced the K imaging unit and the 2nd transfer assembly. Any thoughts?
  • tech51
    • 846
    Re: Replaced K Imaging Unit - Still Print Quality Issues Bizhub C550
    [ATTACH=CONFIG]19895[/ATTACH]
    Looks like a HV problem to me.
    • jeremyb503
      • Aug 2009
      • 38
      Not to be too stupid here, but is there are troubleshooting process for this?
      • jeremyb503
        • Aug 2009
        • 38
        Is there anyone that could help me out with some troubleshooting steps here?
        Thanks.
          • 22999
          For starters I'd try printing something internal, like a status page, configuration page, it doesn't matter what.
          Do you see any image, or is it resolved? Scanner problem.
          Next I'd start printing single color output pages, either by selecting the specific single color from the op panel, or by printing sample documents of Cyan, Magenta, Yellow, and Black. What colors are affected? If all, look at primary or secondary transfer. If only a single color primary transfer or the specific color imaging unit.
          You got to narrow it down. Make more samples: copies black, copies color, prints black, prints in single color, etc, then post them. =^..^=
          • jeremyb503
            • Aug 2009
            • 38
            Thank you very much for your reply!
            I have attached a photo below. I used the Utility mode and generated test pages, so they are coming from the machines memory not from the scanner or from a computer. The issue appears on all of the CMYK test pages.
            We replaced the second transfer assembly about 2 months ago and the K imaging unit a few weeks ago.
            • jeremyb503
              • Aug 2009
              • 38
              I should also note that the end of the sheet with the problems is the one that is closer to the operators side of the machine.
                • 22999
                Next, I'd emergency stop the machine with a full color image on the primary transfer belt. Look at the developed image. If it shows the image problem then you can rule out secondary transfer. The image hasn't made it there yet, leaving only primary transfer.
                If the image is good on the belt, it's a secondary transfer problem. Look for a problem with the contacts, the fit of the door, the pressure springs, or just a damaged secondary transfer roller. =^..^=
                • tech51
                  • 846
                  The next step here is to generate a test print like the ones you have but stop the machine as the print is exiting. Then remove the transfer belt and see if the image is formed properly on that. If it is then its a second transfer problem. If not you may have a faulty belt unit. By the way make sure the machine is level front to back, just in case. Hells bells, just as I hit the submit button blackcat got in before me!! Still, good to see both sides of the pond are thinking the same way
                    • 22999
                    It's good to see that we're thinking along similar lines. =^..^=
                    • jeremyb503
                      • Aug 2009
                      • 38
                      Not to ask to dumb a question here, but how do I do an emergency stop?
                      And by the way, thanks a million, I really appreciate the reply's.
                        • 22999
                        When you hear the machine start up, pop open one of the doors. It may take a few tries to figure out how long to wait before stopping it. I usually count in my head: one one thousand, two one thousand, three one thousand, ... like that. =^..^=
                        • jeremyb503
                          • Aug 2009
                          • 38
                          Well you were right. I remembered that we still had the old second transfer assembly that we replaced a few months ago, I put it back in and viola the machine prints perfectly. kind of annoying considering that it was an OEM part.
                          Thanks for all the adivice looks like this problem is solved.
                          On another note I need some new rollers for the machine, you folks have any leads on where I should get them?
                            • 22999
                            If your not a dealer, we usually use Printer Toner Cartridges - Copier Toner Cartridges - Printer Parts & Copier Parts for other brand parts. They have good selection. =^..^=
                            • jeremyb503
                              • Aug 2009
                              • 38
                              Thanks again!
