Di450 C13FA code
  • krm
    • Aug 2009
    • 233
    Di450 C13FA code
    I'm thinking the print head is failing. Code comes and goes. I reset all connectors to pwb-b and removed the thumb screws securing PH. Does any one remember the LD1 - LD2 adjustments for this code? Do you lower or higher the values? Will this or other solution rectify this code? Or is the PH needing replacement?
    Thanks for your input.
  • JustManuals
    • Jan 2006
    • 9865
    Re: Di450 C13FA code
    Paul@justmanuals.com
    • Darren King
      copiertech
      • 652
      Service bulletin says to lower both LD1 and 2 by 10
      • krm
        • Aug 2009
        • 233
        Thank you Darren! I could not remember and the service manual is lacking on explaining this adjustment. It is worth a try before replacing the PH. That thing is pricey.
        Thanks.
