Di450 C13FA code
  • krm
    replied
    Re: Di450 C13FA code
    Originally posted by Darren King
    Service bulletin says to lower both LD1 and 2 by 10
    Thank you Darren! I could not remember and the service manual is lacking on explaining this adjustment. It is worth a try before replacing the PH. That thing is pricey.
    Thanks.
  • Darren King
    replied
  • JustManuals
    replied
    Paul@justmanuals.com
  • krm
    started a topic Di450 C13FA code
    Di450 C13FA code
    I'm thinking the print head is failing. Code comes and goes. I reset all connectors to pwb-b and removed the thumb screws securing PH. Does any one remember the LD1 - LD2 adjustments for this code? Do you lower or higher the values? Will this or other solution rectify this code? Or is the PH needing replacement?
    Thanks for your input.
