Dialta Di200f scanner bed shakes and will not scan for copies.
  • motherslawn
    [Jamming] Dialta Di200f scanner bed shakes and will not scan for copies.
    I have a Minolta Dialta Di200f. The scanner arm will not move and shakes rather violently. The machine will give a fatel arror and reset. Is this a easy fix? It is a old copier and I want to fix it myself or send it to the bone yard.
    David
  • darry1322
    • Oct 2010
    • 817
    Re: Dialta Di200f scanner bed shakes and will not scan for copies.
    Check the foil coating on the back of the exposure lamp. If it has a cut spot you need a new lamp.
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      That spot may resemble a bubble in the foil.
      • motherslawn
        Will that cause the scanner arm to shake and not move?
        • Hansoon
          • Sep 2007
          • 3385
          Yes, cracks or bubbles in the foil will cause arcing. Logic circuitry doesn't like that.
          Sometimes you can put a dab of solder over the crack(s) to ensure conductivity over the whole length of the foil.
          Hans
