C220 No Cyan Density!
  • Gaffers01
    • May 2011
    • 333
    I have a C220 that has no cyan density all other colours inc Black are fine.
    I have attached some prints for you to have a look at, I cant get my head around this one.
    I know of a problem looking at Infohub with the black clutch but as far as i can tell the CMY are all driven by the same clutch.
    Any ideas will be gratefully appreciated
  • JR2ALTA
    • Feb 2010
    • 2028
    Run a cyan print, stop and look at drum, if solid replace transfer belt. The belt has cams that drop down for CYM individually
      • 22927
      Re: C220 No Cyan Density!
      I like your diagnostic method of pulling the cleaner 1/2 way. It reminds me of the days of analogs, when we would put tape on the primary to block primary charge to diagnose paper skew versus optical skew. Of course, on digitals blocked charge means a solid developed image rather than an analog void.
      One new tool in my arsenal. Thanks! =^..^=
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • Gaffers01
          • May 2011
          • 333
          Yeah I tried that but there is just spotting on the drum not a Solid.
          I have tried replacing the HV board but that hasn't made any difference I think my next stop is the PH assy.
          • RRodgers
            • Jun 2009
            • 1947
            I'm thinking laser.
            • Gaffers01
              • May 2011
              • 333
              Hi,
              Just to let anyone know that has this problem, it was the Laser unit (PH ASSY).
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                the ph unit is a common issue on these machines, I've had this issue too.
                You also have to pray that the new laser unit isnt handled by morons as theyre quite fragile.
                I had a pissed off customer to contend with and when i returned to fit the new one found that all the mirrors had fallen out internally. I pulled it apart and spent half an hour correctly reinstalling every single one of the clipped in mirrors. 3 removals and reinstalls were required before i had it aligned properly. Once done never heard back from them, problem solved.
                • RRodgers
                  • Jun 2009
                  • 1947
                  Originally posted by Gaffers01
                  Hi,
                  Glad you let us know.
