Bizhub C360
  • Nelo
    • Aug 2025
    Bizhub C360
    Got a bizhub C360, no finisher attached but displaying messages 1) Z - fold cannot be used currently, 2) Hole punch cannot be used currently, 3) Only black and white printing is now possible. Need assist in having this warning messages removed from display panel.
    • 23009
    Re: Bizhub C360
    Two places to check:
    1) in Utility/Counter > check the Consumable List to see if the color developer units are due for replacement
    2) in service mode check System 2 > option board installation > set or unset (it sounds like someone enabled a bunch of options that are not installed).
    • JustManuals
      • Jan 2006
      • 9838
      Re: Bizhub C360
      Paul@justmanuals.com
      • Nelo
        Re: Bizhub C360
        Thanks, changed all deve units and the "print black and white only is possible" is gone. In the service mode Syst 2 does not have option boards for finisher. Even no related funtions to set in Sys 1, problem unit isolation section as in the c224's.
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          Re: Bizhub C360
          Goto the trouble isolation menu in service mode and correct the settings as required.
          If it's not this, it may have a failed PRCB or corrupt NVRAM,
          I would hope the machine is running the latest firmware.
