Having a heck of time with this one. The Doc Feeder works great until trying to scan to email then it will run 3 and stop without any code. We've replaced almost the whole thing to diagnose it and cant find anything in the manual about this problem. I'm thinking it might need a firmware update but not sure. Any suggestions would be appreciated!
Bizhub C451 Doc Feeder only jams when scanning...
Re: Bizhub C451 Doc Feeder only jams when scanning...
It sounds like a memory issue to me, not anything mechanical. What type of scanning? How much memory? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
That's where I would start. Keep in mind that you'll have to re-install the video and audio file if you re-format the hard drive. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
All the newer models of KM store the jam help files on the HDD as audio and video. Perhaps this older version does something different, but I don't think so. Take a look at your manual. I'll take a look when I'm near one. =^..^=
EDIT: The only thing I can find on this topic is the following:
• When XPS Enable Format/XPS Disable Format is performed, HDD is logical formatted.
Therefore, font data, macro data, and others that have been installed by users
will disappear.
I'll check further on the Help files.If you'd like a serious answer to your request:
