C253 Ratched noise
  • habik
    • 2013
    C253 Ratched noise
    Just want to post that in case you get a really heavy ratchet noise coming out of your c203_253_353 it is most likely caused by a compacted toner in toner hopper, the actuall auger mechanism gets so packed up that you have only 2 options.
    1, Get a thin spring stretch it out with no hook at the end try and dissolve any hardened bits in the hopper, be carefull though NOT to damage the toner hopper spring mechanism. Just continue shifting the spring wire along the auger inside to the end and back few times.
    now my case
    2, FULL disassembly of the machine. Made a little video with description.. please ignore and leave out the Laser LED erase lamp comments
    Firmwares HERE
  • habik
    • 2013
    Re: C253 Ratched noise
    now my case
    The actual problem Cyan Hopper auger mechanism.
    Firmwares HERE
    • habik
      • 2013
      Firmwares HERE
        • 22999
        Nice video habik. Can you include the 3 hours that got you to that point of disassembly, then the 3 hours of reassembly?
        Just kidding. It looks like a nasty job. =^..^=
        • Hansoon
          • Sep 2007
          • 3374
          Like to know what is causing this? Humidity or is developer coming into the waste toner chute?
          Is it OEM toner?
          Hans
          • SmellsHot
            Head Tech
            • 512
            I had this happen last year....What a nightmare. I kept thinking that there has to be an easier way to get to the auger system. geezee what a nightmare....
            Good video!
            Everyone has the right to be stupid. Some people just abuse this privelage more than others
            • habik
              • 2013
              Without kidding is more than 3hrs...If you know as I know now what to take out then maybe you can do it in 4hrs.
              As I did not know, I was almost taking out the Laser ass'y in whole, when I realized that some chasis parts are coming out..I said to my self STOP! and tried again alternative routes.
              Was thinking of doing time laps on re-assembly that could be fun.
              Firmwares HERE
              • habik
                • 2013
                Is it OEM toner?
                Hans
                Humidity is for sure a factor to take into account.
                Initially I thought it was waste auger blocked and stopping GEAR - 18/30T(ref.9) in Feed/Transport Drive Section to turn and not meshing and causing the ratchet noise problem. That however wasn't the case. I had to go all the way up to toner hoppers.
                Really though to say, all I can think of is toner cartridge not shaken properly.
                OR
                My theory is that the IU was getting clogged (starved IU if toner sensor failed) and it builds up all the way to the top and as the auger is the only bit where there is direct pressure and compactness can be created that is how it all happened.
                We use OEM on colours!
                I am thinking to make a tool that would not mess the hopper spring mechanism that suppose to break the toner before it goes to the auger bit. and yet it would be flexible to go around the auger screw.
                Firmwares HERE
                • avecosat
                  • Jun 2012
                  • 304
                  Is the second option I had the same problem and only cleaned the toner hoper and changed the two gears , when start the machine the noise was out but it coming to replace the toner again into the cyan IU until the the toner hoper and the IU was clogged again and the noise back . I cleaned again and changed the IU cyan and the problem dissapear for more of two months
                  • PeterG
                    • 177
                    You know. After looking at that video I sometimes wonder how the hell we manage to do our jobs.
                    Often I have taken a copier down to that sort of level & wondered how the hell I am ever going to get it back together again. Somehow or other I always manage.
                    If only other people appreciated our ability.
                    • MAD0RAM
                      • Oct 2012
                      • 81
                      How many times have you got it most of the way back together, Looked down and saw a piece that needed to go in earlier.
                      Been there, Just chuckle at myself and start removing parts.
                      • Vy2
                        • Mar 2013
                        • 27
                        Originally posted by SmellsHot
                        I had this happen last year....What a nightmare. I kept thinking that there has to be an easier way to get to the auger system. geezee what a nightmare.... Good video!
                        Is it something that is doable? I had a reply on a different thread saying that it's not doable...i'm facing this same problem right now :|
                        • PeterG
                          • 177
                          If a man built it, a man can repair it!
                          Is it cost effective? That is another thing.
                          • habik
                            • 2013
                            That is true!
                            I think my second machine which I am facing to do now is going to be slightly faster repaired
                            I think of timelapse with some clock on the wall and a cool-box full of beer next to it, as London turned tropical this week.
                            Firmwares HERE
                            • EarthKmTech
                              Step aside, noob
                              • May 2009
                              • 2139
                              for what these old machines are worth, this fault I now consider terminal on a contracted machine.
                              Its easier to grab a returned machine in line for the crusher and give it a second life.
                              If its pay as you go, a quote for 24 hours labour will sort it out.
