Bizhub C352
  • darkknight
    • Oct 2011
    • 24
    [Misc] Bizhub C352
    Hello All!
    I have an issue with a C352. The data light blinks, but no print jobs come through. I have crossed over to the machine with no avail, I have also initialized the data in the machine. Does anyone have any ideas. The customer has windows 7 (64) and it has pcl loaded...
    Thank You all for your time....
  • JustManuals
    • Jan 2006
    • 9838
    Re: Bizhub C352
    Paul@justmanuals.com
    • SmellsHot
      Head Tech
      • 512
      Re: Bizhub C352
      sounds like user authentication or account track is turned on.
      Everyone has the right to be stupid. Some people just abuse this privelage more than others
      • oldschool
        • Mar 2007
        • 245
        Re: Bizhub C352
        If you are using the Vendor 2 setting than all print jobs have to be sent as secure print jobs.
        Jamex Tech Support: Saving the world one phone call at a time.
        • DigiMan
          • Jan 2013
          • 262
          Re: Bizhub C352
          Most likely password'ed,check Authentication/Account Track settings in the print driver.
          I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
          • darkknight
            • Oct 2011
            • 24
            Re: Bizhub C352
            Thanks to everyone for your replies, unfortunately, I wish it were as simple as authentication or account tracking, neither is being used. Any other suggestions?
            • dshiels_17
              Re: Bizhub C352
              [QUOTE=darkknight;353657]Thanks to everyone for your replies, unfortunately, I wish it were as simple as authentication or account tracking, neither is being used. Any other suggestions?[/QUOTE
              Re-install the print driver and try.
              • tech51
                • 846
                Re: Bizhub C352
                Any deleted jobs in the log? If not then I would try connecting a laptop to it to verify the printing. I have had issues with W7, particularly the 64bit version on newer models than the c352!!
                • darkknight
                  • Oct 2011
                  • 24
                  Re: Bizhub C352
                  Thanks for the reply, yes I have already crossed over to the machine and could not print, additionally I tried to print directly from the controller to no avail also...
                  • tech51
                    • 846
                    Re: Bizhub C352
                    What controller is it? Fiery or the built in one. Does it have a fixed ip address and can you ping it?
                    Are you saying you can't get any test prints from the machine at all (config or demo) and has it printed successfully in the past?
                    • darkknight
                      • Oct 2011
                      • 24
                      Re: Bizhub C352
                      Emperon controller, static ip, yes it can be pinged, no it does not print demo pages, yes it printed in the past....
                      • AjitN
                        • Mar 2009
                        • 287
                        Re: Bizhub C352
                        Once I had same problem on C353. I resolved it by reloading the firmware.
                        Hope this helps.
                        • marlon29
                          • May 2011
                          • 51
                          Re: Bizhub C352
                          hi,
                          maybe the setting for the controller is not correct in the system if it has fiery controller. Try setting to "controller 1"
                          • darkknight
                            • Oct 2011
                            • 24
                            Re: Bizhub C352
                            Hope this helps.
                            thanks so much, firmware resolved the issue...thanks again
                            • jagatiswaran
                              Re: Bizhub C352
                              go to service mode - look for image controller - make sure its stated on mode 1 - maybe it helps
