Bizhub C352
  • Hansoon
    • Sep 2007
    • 3391
    #16
    Re: Bizhub C352
    thanks so much, firmware resolved the issue...thanks again
    Well based on his feed back he solved it already....... Four weeks ago...............
    Hans
    • rbridges
      • Dec 2014
      • 12
      #17
      Re: Bizhub C352
      Hi,
      I know this is an old thread but I thought somebody might still be around to help.
      I also have a C352 where the network settings have been setup incorrectly and now the network settings tab has disappeared. The copier can not be pinged right now so the only option I believe I have is to perform a nic recovery firmware update from a compact flash card but every time it just says invalid card.
      Can anyone recommend a 100% compatible card?
      Cards I've heard may work:
      Sandisk Ultra 2 256MB
      Sandisk Shoot & Store 128MB
      Thanks Rob.
      • rbridges
        • Dec 2014
        • 12
        #18
        Re: Bizhub C352
        Hi,
        ** Problem Solved **
        To anyone missing the network settings tab in administrator settings and also the image controller tab in service mode the solution that solved it for me was ARP and PING. Immediately after the successful ping the missing menu tabs reappeared and I successfully managed to print a test page.
